VPN50 SSL - connection allowed only first user
Antonio1976
I have ZyWall VPN50.
I have configured SSL VPN but only the first user is allowed to connect, from second SecuExtender cannot connect.
This is the message log:
[ 2020/10/30 15:56:43 ][SecuExtender Helper] ==============================
[ 2020/10/30 15:56:45 ][SecuExtender Helper] Request(106): REMOVE 4079724736/3052283741 21 4294967295 4294967295
[ 2020/10/30 15:56:45 ][SecuExtender Helper] Remove Routing
[ 2020/10/30 15:56:45 ][SecuExtender Helper] Remove prioritize routing
[ 2020/10/30 15:56:45 ][SecuExtender Helper] Failed to change default route
[ 2020/10/30 15:56:45 ][SecuExtender Helper] Get netsh path = powershell
[ 2020/10/30 15:56:45 ][SecuExtender Helper] Set-NetIPInterface -InterfaceAlias "Ethernet 2" -InterfaceMetric 30
[ 2020/10/30 15:56:45 ][SecuExtender Helper] ZyShellExecute start.
[ 2020/10/30 15:56:47 ][SecuExtender Helper] ZyShellExecute WaitForSingleObject() result = 0
[ 2020/10/30 15:56:47 ][SecuExtender Helper] GetExitCodeProcess
[ 2020/10/30 15:56:47 ][SecuExtender Helper] lpszFile = powershell, lpszParam = Set-NetIPInterface -InterfaceAlias "Ethernet 2" -InterfaceMetric 30, dwExitCode = 1, dwError = 0
[ 2020/10/30 15:56:47 ][SecuExtender Helper] Failed to read from client(2): 109, 0
[ 2020/10/30 15:56:47 ][SecuExtender Helper] Start to Disconnect pipe...
[ 2020/10/30 15:56:47 ][SecuExtender Helper] Shutting down a pipe connection instance...
[ 2020/10/30 15:56:47 ][SecuExtender Helper] ==============================
To collect complete information,
after issue occur,
1. Please Go to My PC>Local Disk C
Collect "SecuExtenderHelper.log"
2. and then Go to My PC>Local Disk C>Users>select the file of account which you login
Collect "SecuExtender.log"
Please provide message the information for check further.0 -
Now vpn works well.
I had to restart ZyWall and now there aren't problems.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
