MULTIPLE VPN USG
SEPHYROTH21
Hello everyone, sorry for my bad english, but I m french.
I need hello to Know if I can create 2 VPN clients to site on 1 USG 40.
I have 1 connection with 1 public ip adress coming on my usg 40 wan port.
I have 1 client to site VPN PPTP connection gong to 1 server 2012 R2 on port LAN 1 using windows agent on clients.
Can I have a second client to site VPN L2TP connection gong to a second server on te same site, but on port Lan 2?
Lan 1 is on 192.xxx.1.xxx
Lan 2 is on 192.xxx.2.xxx
Tanks for your help
Tanks for your help
@SEPHYROTH21
After L2TP established, if you want to force L2TP client access to Second Server via Lan2, you need to add the Routing.
Hello, and tanks for your answer.
Ok. I want that my first PPTP VPN Stiller goes on on server 1 on LAN1.
Can you help me creating the second VPN with L2TP IPSEC protocol going to the second server on LAN 2?
About 10 users will have to connect with L2TP
When I create the L2TP VPN on the second server, and when i try to connect the client from Internet, the connection never succed.
Thank tou very much for your help0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
