GoIP blocking USG310
Aleksandar Aleksandrov
Hi All,
I am receiving some SYN attacks on
my site recently. They all come from different countries and every time
I am blocking the country, adding a new rule.
Is there anyway
that I create a rule to disable all incoming traffic, except the IPs
from a certain GeoIP location? The idea is that my site is used only
from 1 country and no one outside this country must be able to connect
to it.
Thank you,
Aleksandar Aleksandrov0
@aaleksandrov
You need to create the GEOGRAPHY address group
Go to configuration>Object>Address/Geo IP>Address> Create profile for each region
Go to address group to Group all regions: all_world
Create the IP address which you want to allow
Go to Security Policy>Create any to any, Source:all_world, Deny > Create any to any, Source:Allow_IP, Allow
Thank you very much.Unfortunately I cannot add continents.For example if I want to block all requests from Europe, I need to create a row for each country in the Addresses tab and then create a group with all created GeoIP addresses.Is there any way that I can add directly continents?Thank you0
@aaleksandrov
What firmware version are you using?
To create address for continents, you just Go to configuration>Object>Address/Geo IP>Address>Select GEOGRAPHY on Address Type>Select continent on Region type
Hi,Thank you for update and sorry for my delay.The version that we currently have is 4.33. We have scheduled a firmware update.After we upgrade to 4.60, are we going to have the option to block/allow continents?Thank you,Aleksandar Aleksandrov0
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
