win 10/Android 7.0 phone connecting to the PPTP VPN over 4G disconnects when idle for some minutes.
PeterUK
PeterUK Posts: 3,740  Guru Member
edited April 2021 in Security
VPN2S  1.20(ABLN.2)
So I setup a PPTP VPN server on the VPN2S I connect to it by my phone that got Android 7.0 when doing nothing and idle for some time past the VPN connection disconnects and does not stay connected.
also happens with win 10 over 4G too
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034  Zyxel Employee
    @PeterUK
    It's normal behavior that if there is none of traffic on PPTP tunnel, the tunnel will be disconnected in the seconds which you set on the Keep timer filed.
    Otherwise, the tunnel can be alive for mins because after tunnel established, server and client will send negotiate packet in the tunnel in the beginning.
    Charlie
    If the keep alive timer is set to 1 with a reboot to set it when no traffic being sent the keep alive timer sends a echo request back to the client from port 1723 every second this is to keep the connection alive but does not keep the GRE tunnel alive.
    So the keep alive timer is to stop the tunnel from closing but fails to do so because it does not keep the GRE tunnel alive only the PPTP port by TCP.
    If keep alive timer is set to 1 second it takes minutes before the tunnel disconnects not the tunnel will be disconnected in the seconds which you set on the Keep timer filed.
    If you can make the keep alive timer send a ping to the client by GRE this will solve the disconnection problem.
  • Zyxel_Charlie
     @PeterUK
    Can you screenshot the configuration on PPTP page? I would like to check it on my lab.
    edited October 2020
    Note that I made a firewall rule for PPTP from WAN to router which seems to auto allow GRE also the keep alive timer set to 1 only works after a reboot.
  • Zyxel_Charlie
    @PeterUK
    Is it your purpose to let the PPTP tunnel stay connected even PPTP client idle for a while?
    edited November 2020
    @PeterUK
    Yes and I thought the keep alive timer was to do just that, the only other way to keep the tunnel open is for the client to send a ping.
  • Zyxel_Charlie
    @PeterUK
    We dont have any plan in certain enhancement. However, to have further evaluation, I would like to move this case to Ideas.
  • vuphung
    vuphung Posts: 2
    Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch
    Dear Zyxel team, could you update the keep Alive Timer feature in Nebula cloud, I need this feature, thanks
