ATP 500 L2TP AD loggin don't working after 4.60 update
ticsystems
ZCNE Certified
ZCNE Certified
Hello all!
My ATP 500 after update appers offline in AD computer then l2tp loggin don't working.
My device is added to the domain with AAAserver and it quickly appears offline in AD users and computers.
I dowgrade my device to 4.55 and starts working.
Thanks for the help and sorry for my english
@ticsystems
Regarding to this case,
after update to firmware 4.60, the L2TP client can do authentication using AD account successfully on my lab.
The below is my test result,
Firmware: 4.55
Created the account on AD:charlie
The L2TP can be established with AD account
After upgraded to FW: v4.60
The L2TP still can established by AD account
Can I know what AD server are you using?
My versión Windows Server 2016.
What is your version?
Thanks0 -
@ticsystems
The result I posted is related with windows Server 2012.
Does the issue still appear, after you reconfigure, and verify the AD setting with v4.60?
Since we also had tested v4.60 with win2016, it operated successfully.0 -
¡¡Hola!!Acabo de configurar el otro ATP 200 de la empresa.Con 4.60 esto sucede:
Bajé a 4.55 y luego:
En la versión 4.55, el atp se agrega correctamente al dominio. A los 4,60 pierde dominio.
¡¡¡¡Gracias!!!!0 -
- 441 Beta Program
- 292 Service & License
