Slow 5Ghz wireless speed ?
@hp1
The throughput will be affect when you enable the Firewall or UTM profiles.
Since the firewall need to check and analyze each packet, therefore, it will consume numerous performance.However, on firmware v4.60, we have implement fast forwarding feature which can let performance to reach better level.
The below result in our lab with v4.60
Firmware: v4.60
Go to configuration>System>Advance>Check Fast forwarding
In our lab test with 1G ISP connection, and tested with speedtest website
On my lab, with enable fast forwarding function, the performance can achieve 531.21Mbps. However, the statistic of throughput may be different by test machine or test process or test environment.
hi charlie,
so the fast forwarding feature will disable/affect the firewall?
any details so far when v4.60 will be available? nevermind, found it in the download area, will test asap.
kind regards0 -
Hi @Harska@Zyxel_Charlie / @hp1 / All
After the update to v4.60 and enabling the Fast forwarding option
" Go to configuration>System>Advance>Check Fast forwarding "
I'm having the correct speed
Wired
And wireless 5Ghz
Wireless 2.4Ghz
So definetly it is a box performance issue...
If we use all the features the equipments do not handle with a 500Mbps link.
Thank you for your support
thank you for your support, i'm getting stable 500/50mbit now with fast forwarding enabled.1
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
