USG40w DNS zone forwarder
IT_Field_Support
I have a question regarding the way the router work with dns for external zone.
For exemple :
My router's name is router
My domain name is : city.country.test.hq.compagny.com
Localy, my dhcp clients on the lan get IP and dns suffix city.country.test.hq.compagny.com and I can resolve localy all the hosts that have DNS records in the router.
Now, I want to be able to resolve the DFS name of the HQ through a VPN tunnel, so I have setup a domain zone forwarder as this :
Domain zone : hq.compagny.com
Type : User-defined
DNS Server : ip of the DC
Query via : Tunnel
The DFS name is logicaly : hq.compagny.com
Now, if I do an nslookup on a laptop connected on the LAN of my router it don't work at all.
It seems that the router add to the DNS request the domain name of the router which is at the end :
hq.compagny.com.city.country.test.hq.compagny.com
How I can setup the DHCP, or the DNS forwarder or anything else so I can resolve the DFS name ?
Thank you for your time,
Davy
I think you need to create the static route
Example:
DNS server is 192.168.10.X
Local gateway: 192.168.1.1
I'm not sur I need to add this route because I can already ping the DFS using the IP directly. The problem is only with the name resolution.ThanksDavy0
As I know, you need to create static route to let DNS session flow in tunnel.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
