RDS connections slow with IPSEC
romain71570
I have several remote sites where a USG40 connects with IPSEC VPN to the headquarters (where there is a USG310).
Several sites complain about slow RDS connection.
Do you recommend a specific setting for RDS connections via IPSEC?
My settings are as follows: Ikev2
VPN gateway: AES128, SHA1, dh1
VPN connection: AES128, SHA1
thanks for your advices
You may adjust the algorithm and check it again. VPN gateway: DES,MD5, DH1, VPN connection: DES,MD5,DH1. If several clients communicate with peer simultaneously, the RDS connections will be effect.
- 601 USG FLEX H Series
- 480 News and Release
