Ping using Virtual interface causing packet loss for WAN to BQM
So I'm back to V4.38(AAAA.0) on Zywall 110 after finding this bug in V4.60(AAAA.0)
On the OPT I have Virtual interface for a LAN 192.168.252.1 and OPT gets the WAN IP but as you can see from this capture every now and then it uses the Virtual interface and not the WAN IP on OPT to send a reply.
I also have a routing rule for incoming ZyWALL source OPTIP next hop OPT which fails to help.
@PeterUK
To reproduce this issue,
I would like to confirm the test steps from you.
1.Create virtual interface(Lan IP) base on OPT.
2.Ping to 8.8.8.8 from Lan PC, and packet capture on OPT interface.0 -
No not ping from LAN these are pings incoming to OPT using BQM
https://www.thinkbroadband.com/broadband/monitoring/quality
The issue also happens with V4.39(AAAA.0)ITS-WK38-r96153 if that helps
Was caused by these rules which I hope a don't need any more
Ping request gose in on OPT the reply out VLAN443 — Zyxel
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 489 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
