ATP 200 last firmware and VPN SSL
Acquatecno
Hello.
since i upgraded to last firmware (4.60) the vpn connection trough SecuExtender 4.0.3.0 doesn't work anymore.
It perfectly work only booting the device with the precedent firmware (4.55).
Any solution?
Thank you to all.
Any solution?
Thank you to all.
@Acquatecno
The SSL VPN(SecuExtender 4.0.3.0) is working without any issue from v4.55 to v4.60 on my lab.
What format did you fill on Server IP? domain or IP address?0 -
ip address....0
Hi AcquatecnoI don't have problems at ATP200 on 4.60 with ssl vpn.Is it an local user?And are you able to logon on the webinterface with this user/pass?You can check the SecuExtender.log on c:\users\USERNAME\ for errors?ThanksMario
@Acquatecno
To collect complete information,
after issue occur,
1. Please Go to My PC>Local Disk C
Collect "SecuExtenderHelper.log"
2. and then Go to My PC>Local Disk C>Users>select the file of account which you login
Collect "SecuExtender.log"
Please provide message the configuration and above information for check further.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
