server behind the usg40
hi,
when my laptop is inside lan I can find the server by Ip or name, e.g in explorer I can find it with \\192.168.8.8 or \\SRV-SIDE-1.
When I go to my customers an use the same laptop outside lan by SecuExtender VPN SSL client I can see my server just with IP 192.168.8.8 but not with \\SRV-SIDE-1 name.
Why?
thank you!
Why?
thank you!
Found another thread discussing this, perhaps it helps.
https://businessforum.zyxel.com/discussion/5021/ssl-vpn-netbios-issues#latest
have you checked for SSL VPN "NetBIOS broadcast over SSL VPN Tunnel"?0
Hi, thank you, for your help!0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
