[Release Note] SecuExtender - Software (Mac OSX) Version 1.2 has been released!
Zyxel_Charlie
Updated: Issue-The application crashed after access to About Menu.(Solved)
Release Version 1.2.1 – 2020/11/23
It has been solved by Secuextender 1.2.1.
Download SecuExtneder 1.2.1
SecuExtender
SecuExtender
Software Release Note
(Mac OSX)
Release 1.2
Release Version 1.2 – 2020/11/13
Modification for:
- SecuExtender has
been updated to support macOS 11 (Big Sur)
THX, the program works, I can make vpn connections... but
when I press the button "Registration" the program crashes. 30 days left.
THX.
Alex0 -
I can confirm the response from Alex. Although, I tried Registration a second time and found that it now does nothing but does not crash.0
I also confirm this.
Also, an employee of my company confirmed that if the previous version of the client 1.1.9 was installed and registered, then the registration remains during the update.0
I know it, but I have a fresh installation now and I'll have a new device (replacement).
THX.0 -
@Brad & @Alex68 & @icebird78
I have updated the macOS to 11 (Big Sur), and the license still can be registered.
Can you private message your license number of SecuExtender for check further?0 -
The problem is not in the key itself, but the problem is that when you click the Register button, the application crashes, when installed on a new computer, not upgraded.
@Baymax7 & @icebird78
We could not reproduce this case. If is it possible, can you private message video which record this issue you reproduced or share remote access for check purpose?
Also, do you have another mac to cross check? since we did not face this issue on our site.0 -
@Zyxel_Charlie - I will private message a video and the crash report.
- 441 Beta Program
- 293 Service & License
