Quick Ping for Switch
JINHANG
ZCNE Certified
ZCNE Certified
To test link reliability, we need quick ping on the switch. Here is example from other vendor:
SW01-CORE-L3-0205-F3> ping 192.168.12.21 source 192.168.12.19 rapid count 1000 size 1500
PING 192.168.12.21 (192.168.12.21): 1500 data bytes
--- 192.168.12.21 ping statistics ---
1000 packets transmitted, 996 packets received, 0% packet loss
round-trip min/avg/max/stddev = 18.219/21.200/49.329/3.176 ms
OR
OR
OR
[admin@XXX-YYY] > tool flood-ping 10.10.205.3 count=1000 size=1500
sent: 1000
received: 1000
min-rtt: 16
avg-rtt: 21
max-rtt: 179
OR
plunger#ping 192.168.0.10 size 1500 df-bit repeat 1000
Type escape sequence to abort.
Sending 1000, 1500-byte ICMP Echos to 192.168.0.10, timeout is 2 seconds:
Packet sent with the DF bit set
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 1/2/4 ms
plunger#
Hi @JINHANG ,
We have an internal meeting to evaluate this idea.
In our current design, Switch already have the feature "Ping", so we don't have a plan to add the feature "Quick Ping" in our switch.
If you think Quick Ping is really necessary on the switch, may you share your real application or other concerns with us?
Thanks.Jason0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
