[Release Note] SecuExtender - Software (Mac OSX) Version 1.2 has been released!
Zyxel_Charlie
Zyxel_Charlie Posts: 1,034  Zyxel Employee
Updated: Issue-The application crashed after access to About Menu.(Solved)
Release Version 1.2.1 – 2020/11/23
It has been solved by Secuextender 1.2.1.
Download SecuExtneder 1.2.1
SecuExtender
Software Release Note
(Mac OSX)
Release  1.2
Release Version 1.2 – 2020/11/13
Modification for:
- SecuExtender has been updated to support macOS 11 (Big Sur)
«1
  • Alex68
    Alex68 Posts: 9  Freshman Member
    THX, the program works, I can make vpn connections... but
    when I press the button "Registration" the program crashes. 30 days left.
    THX.
    Alex
  • Brad
    Brad Posts: 9  Freshman Member
    I can confirm the response from Alex. Although, I tried Registration a second time and found that it now does nothing but does not crash.
  • icebird78
    icebird78 Posts: 3  Freshman Member
    I also confirm this.
  • icebird78
    Also, an employee of my company confirmed that if the previous version of the client 1.1.9 was installed and registered, then the registration remains during the update.
  • Alex68
    I know it, but I have a fresh installation now  and I'll have a new device (replacement).
    THX.
  • Zyxel_Charlie
    @Brad & @Alex68 & @icebird78
    I have updated the macOS to 11 (Big Sur), and the license still can be registered.
    Can you private message your license number of SecuExtender for check further?
  • icebird78
    The problem is not in the key itself, but the problem is that when you click the Register button, the application crashes,  when installed on a new computer, not upgraded.
  • Baymax7
    Baymax7 Posts: 5  Freshman Member
    I confirm: I have the same problems with a clean installation of Big Sur
  • Zyxel_Charlie
    edited November 2020
    @Baymax7 & @icebird78
    We could not reproduce this case. If is it possible, can you private message video which record this issue you reproduced or share remote access for check purpose?
    Also, do you have another mac to cross check? since we did not face this issue on our site.
  • Brad
    @Zyxel_Charlie - I will private message a video and the crash report.
