block twitch with FQDN not working with schedule rule
Asgatlat
Asgatlat Posts: 115  Ally Member
First Comment Friend Collector Seventh Anniversary
edited April 2021 in Security
hi,
i setup a FQDN rule for twitch.tv
i've tested it with some computers in the company and it works.
i also set up a schedulde on this rule to allow access during the lunch.
but i found a bug.
indeed if you start a live on twitch during the granted time access, you can still use it until you refresh the page
so some of employees had noticed it and keep their page on the live stream to have it all the work hours....
any idea to fix it ?
i have Zywall 110 with 4.39
    PeterUK Posts: 4,050  Guru Member
    edited November 2020 Answer ✓
    Try a FQDN
    *ttvnw.net
    tested here with USG60 V4.60 and it works
