VPN100 - Edit Ethernet window won't load for LAN interface after upgrading to 4.60(ABFV.0)
Web GUI: Configuration - Network - Interface - Ethernet window won't load after upgrading to 4.60(ABFV.0). It stays at "loading" forever.
This applies only to LAN1 and LAN2. SFP, WAN1, WAN2, DMZ and RESERVED are loading fine.
If I fire up javascript console it gives errors on LAN1 and LAN2 popup windows.
This does not happen on other interface edit window. Only Lan1 and Lan2
Try another browser or clear your browsing data.0
Not a browser issue. Tested with latest Chrome, Edge and Firefox, on both desktop (4 machines, 3 windows, 1 Linux) and mobile (2 devices, android 8, 10).0
Seems to be a bug in javascript.Uncaught TypeError: response[("zyshdata" + i)] is undefinedeachReader xttps://router.intranet.xxx.net/ext-js/app/common/retrieveData.js?_dc=1605741511142:103
callback xttps://router.intranet.xxx.net/ext-js/app/common/retrieveData.js?_dc=1605741511142:74
ExtJS 4
callback
onComplete
onStateChange
bind
You should use other PC connect to VPN100 to see the consequence.0
Same problem on other PC and router:Zyxel VPN 50, V4.60(ABHL.0) / 2020-10-17 04:44:36
@xbolshe
I tested it locally without any issue
FW:v4.60
Wan
Lan
Does this issue occur on previous firmware version?
Also, can you private message configuration for check purpose?0 -
VPN 100 4.60(ABFV.0). I was not able to access Lan 1 as well. All clients are on Lan1. However, other Wan, Lan 2 were accessible and configurable. I reset VPN 100 to factory defaults. I was able to configure Lan 1 after restart. 15 minutes later the Ethernet window would not load again. I am back on 4.35. No problems on 4.35.0
VPN100 4.60(ABFV.0) I have same issue ethernet Lan1 window won't load. Revert to V4.39(ABFV.0) and it works again.0
Hi, I'm having the same issue VPN100@4.60: LAN1 won't load, but all others works just fine.
I'm having the same issue on my VPN100 with V4.60(ABFV.0)LAN1 does not load, while all others do work fineI've tested in on my Mac with- Catalina 10.15.7- Firefox 83.0- Safari 14.0- Chrome 87.0.4280.67on HTTP and HTTPS and even on an iPad with SafariThat issue is definetively related to VPN100 and its latest release V4.60(ABFV.0)0
- 237 Nebula Ideas
- 6.8K Security
- 745 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
