VPN100 - Edit Ethernet window won't load for LAN interface after upgrading to 4.60(ABFV.0)
Zyxel_Charlie said:@xbolshe
I tested it locally without any issue
FW:v4.60
Wan
Lan
Does this issue occur on previous firmware version?
Also, can you private message configuration for check purpose?No. It does not.I see the following problem:After sending commands from 0 to 24 as shown on a picture below, a response like zyshdata + i was returned only for 0 to 16 commands. There is no response for commands 17 - 24. The first command of this list isshow matching mac oui LAN1_POOL,Static_.....
I have deleted manually (via command line) static DHCP records for LAN1 interface. And now it works - see a picture below. So, the bug is related with static DHCP records.Router# configure terminal
Router(config)# interface lan1
Router(config-if-lan1)# no ip dhcp-pool Static_LAN1_xxxxxxxxxxxx
Router(config-if-lan1)# no ip dhcp-pool Static_LAN1_yyyyyyyyyyyy
Router(config-if-lan1)# no ip dhcp-pool Static_LAN1_zzzzzzzzzzzz
Router(config-if-lan1)# no ip dhcp-pool Static_LAN1_cccccccccccc
Router(config-if-lan1)# no ip dhcp-pool Static_LAN1_nnnnnnnnnnn
One more interesting point: VPN50 does not support a comma separated list in a command like shown below. It may be a problem.Router# show matching mac oui LAN1_POOL,Static_LAN1_xxxxxxxxxxxx
% (after 'oui'): Parse error
retval = -1
ERROR: Parse error/command not found!
No. MAC OUI member
1 33:33:33
Router#0 -
@xbolshe , @bbp , @Tom2456 , @Bula64 , @RafaelDalben , @noelchiocchetti , @gb5102
Regarding to this issue, the solution has been released.
You can download from this Link.
THX A MILLION !!! It's working now !!V4.60(ABFV.0)ITS-2020-11-23-201100284
working just fine !! 1 -
@Zyxel_Charlie I confirm that the problem disappeared on VPN50 V4.60(ABHL.0)ITS-2020-11-22-201100284 / 2020-11-22 15:52:44. Thanks a lot!
@Zyxel_Charlie I confirm as well that problem disappeared on VPN100 VV4.60(ABFV.0)ITS-2020-11-23-201100284 / 2020-11-23 09:0. Thanks a lot for your swift support!
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
