What is the recommended procedure to deal with an Expried factory default certificate?
RAI_Tech
RAI_Tech Posts: 1 image  Freshman Member
edited April 2021 in Security
The expired "default" cert is still referenced in the configuration in some places, so I can't just delete it.  Can the default be replaced with something better?  Does it need to have a "default" cert to function?  How do I recreate the factory default cert?  What is the best solution for the expired cert?  Thanks.
  • Jeremylin
    Jeremylin Posts: 166 image  Master Member
    First Answer First Comment Third Anniversary
    As I know, you can go to system>www ,and check the default cert is used by Server Certificate field.
    The certificate also can be used on VPN profile for authentication, so you may check it as well.
