Signature Windows Update
AKSYS
AKSYS Posts: 3 image  Freshman Member
edited April 2021 in Security
Hi.
One a usg without UTM licences,
I'd like to create a custom signature for Windows Update to  avoid bandwith saturation by configuring "BWM Global Setting".
Does anyone can help me to create this custom signature.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    edited December 2017
    Hello AKSYS,
    As your description,
    I would like to confirm that do you want to limit the speed of Windows update?
    If yes, please follow the steps as following.
    Create the application profile which is Windows_update on application page.
    Go to Application>Add>Select Security update tools and press search>tick Microsoft Windows update
    Go to BWM>ADD>Select Application Object and also choose "Wupdate" profile>Limit inbound and outbound of the speed of windows update under 500kbps
    Enable BWM feature, and press apply.
    Charlie
  • AKSYS
    This method does not work because we have an USG without licences UTM (Zyxel support)
  • AKSYS
    Have-you got an idea to create a signature ?
  • Zyxel_Charlie
    Hello AKSYS,
    For this method,
    the IDP/AppPatrol license is required, so if you dont have license on USG, the solution does not work.
    Charlie
