show conn problems in USG60W and USG40W on 4.39 and 4.60
danyedinak
At the CLI, typing the following command :
There's also a problem with :
show connand hitting tab, reveals the following sub commands.
<div>; begin dstcc fastpath service srccc user </div><div><cr> destination end ip-traffic source status | </div>Usually, when a semicolon (;) appears as one of the options, the command can simply be run at that point. However, hitting enter here results in :
<div>Router# show conn;</div><div>Valid range in USG60W: <1..100000></div><div>retval = -1015</div><div>ERROR: Invalid range specified.</div><div></div>
show conn srcccFirst, the documentation in the CLI reference guide incorrectly shows this command as :
show conn srtccSecond, hitting tab after the correct command produces the following :
<div>Router# show conn srccc </div><div><countey code> any private-ip </div>
Note that "country" is misspelled as "countey".
Here, again, the semicolon is misleading, as it is also requiring a range :
<div><div><div>Router# show conn srccc any </div><div>; <cr> begin dstcc end fastpath | </div><div>Router# show conn srccc any </div><div>Valid range in USG60W: <1..100000></div><div>retval = -1015</div><div>ERROR: Invalid range specified.</div></div></div><div></div>
The only way to continue is to include a range, as in :
Verified these problems on two different USG60Ws, one running 4.39(AAKZ.0) and the other 4.60(AAKZ.0) and a USG40W running 4.39.
Router# show conn srccc any begin 1 end 50
@danyedinak
Can I know do you type the command via web console? If so, can you access USG40W with Incognito window or clean browser cache and check it again.0 -
@Zyxel_Charlie
Nope. Connected via SSH. No browser involved.0 -
@danyedinak
I used putty and tera term and the issue did not occur.
Can I know what application did you ssh to device? Putty or?
Can you private message remote access for check further? I would like to connect to you device via ssh.0
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
