ATP100: SFP/Modem little bit slow?
Hi folks!
I have a ATP100 here and when I also use it as a modem with plugged-in WAN fiber cable directly into the ATP100, I receive between 400-500Mb/s in download-transfers (multiple streams, different servers tried etc.).
When I use the original modem of the provider (Swisscom, Internet-Box 3), I receive 960Mb/s per second. Of cause I don't expect these rates behind the firewall, but when I make a forwarding from the provider modem to the ATP100, I receive 650-700Mb/s which is pretty nice.
I want these rates directly from the ATP100 with plugged-in WAN fiber, but it seems to much for the ATP100?!
Do I have to swap to the ATP200 to get these rates?
I know that the ATP500 could handle this for sure, these firewalls are beasts, but I don't won't to spend this much in my Home-Setup.
Sorry for my strange spelling.
Greeting from Switzerland
Best Regards
Jonas
Best Regards
Jonas
Yeah… I should say, that this was of course, all ATP features were activated. All my fault. Sorry for the late response
Did the ATP100 connect with modem by Ethernet to get performance 650-700Mb/s ?
Yes...Jeremylin said:Did the ATP100 connect with modem by Ethernet to get performance 650-700Mb/s ?
Fiber-cable with SFP/miniGBIC from the wall-socket into the modem. From the modem with Ethernet (copper) into the WAN of the ATP100. Speed: 650-700Mb/s
Fiber-cable with SFP/miniGBIC from the wall-socket into the SFP-slot of the ATP100. Speed: 400-500Mb/s
Firmware is V4.60(ABPS.0).
EDIT: Perhaps I should add, that I receive 960Mb/s without the ATP100 at all (so just with the modem). So the fiber-WAN is not the problem.0 -
- 238 Nebula Ideas
- 6.8K Security
- 748 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
