Schedule is not working in Policy Control
Hi, I have a firewall rule WAN --> LAN with service: FTP. I only want to have that port open during business time (say 9:00 -17:00). So I made a schedule with this time frame and added i to the firewall rule. But after the time schedule the port is still open. What is going wrong?
Hi @Fender
I setup time schedule 14:00~14:15 to allow specific service from WAN to LAN.
And it looks traffic will block after time frame.
According to your FTP service port still alive, you may have a check if USG local FTP server is enabled or not.
Tested here with a USG40 V4.60 by from WAN to DMZ bridge and works fine.
top rule allow from WAN to DMZ FTP and schedule then a rule under that to deny from WAN to DMZ FTP.
Maybe you have another rule allowing FTP?0 -
Hi @Fender
Hi Stanley, your last screenshot, the USG local FTP server was checked. So when I tried a FTP check with http://scanner.openportstats.com/ the port seemed to be open. I unchecked it now, thank you!0
- 603 USG FLEX H Series
- 480 News and Release
