Licensing change?
I have a USG 40 with an older firmware (4.32) and checking on the site I see that the latest version is 4.60. I noticed that from 4.35 the license version is displayed as 'SHARE' instead of 'USG'. Up to 4.32 the license was displayed as USG. I'm reluctant to upgrade, not knowing what this change means. Does anyone know the difference?
The SHARE license went back to USG after the reboot. Also interesting that depending on what method yo use, you get a different firmware version. Licensing portal: 4.60, Cloud Update on USG: 4.39. I updated to 4.39 and everything is fine.0
VPNRob said:The SHARE license went back to USG after the reboot. Also interesting that depending on what method yo use, you get a different firmware version. Licensing portal: 4.60, Cloud Update on USG: 4.39. I updated to 4.39 and everything is fine.
The version issue was due to Zyxel pulling 4.60 right after it got released to fix a critical security issue. When the Patch 1 version came out it seemed to hit the download servers before showing up in the cloud query.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
