No Data - Most Popular Websites
Hi @iSpeed
You may have a check if these settings are enabled on your ATP.
(1) Log all web page function in Content Filter is enabled.
(2) Applied Content Filter function in to Policy Control rule.
(3) Enabled "Forward web site" in Log Category setting.
Configuration > Log & Report > Log Settings > Log Category Settings.
(4) Enabled "Collect Statistics" function in Content Filter.
Monitor > Security Statistics > Content Filter.
(5) Wait for around 10~15 mins, SecuReporter will display it after analyzed.
I have an ATP200 with same settings that is pulling data normally. The only above was the "forward websites tick" was disabled. Same setting on my ATP200 and it pulls data normally.0
I think what's happening is I'm not getting any data from https sites. I'm probably missing something with SSL service0
Hi @iSpeed
You may double confirm “Enable HTTPS Domain Filter for HTTPS traffic” function is enabled in Content Filter.
After enabled it, Content Filter function will inspect HTTPS request.
If you enabled “Forward Web Sites” in log category settings.
Monitor > Log will display URL forwarded those inspected.
It is an optional setting for SecuReporter.
Thanks for your sharing.
Stanley, Yep the https domain filter was turned off. I was having a problem with it blocking certain youtube sites. I'm also noticing the 4.60 firmware seems to have been pulled? Do you know status? I have another FW to upgrade.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
