convert settings from USG100 to USG210
Hello community,
I'm desperate right now. The attempt to convert the settings from the USG100 to the USG210 fails with:
ERROR: #configure terminal wlan slot1, parse error / command not found!
For conversion, I use https://convert.cloud.zyxel.com, which has worked well with all other USGs. On both USGs are the newest firmware.
Hope that someone have a idea.
Please call our support hotline.. we can modify the config for you
Hello weite,
For this case,
I would like to check your configuration locally, so please pm your configuration for checking further.
Charlie0
- 603 USG FLEX H Series
- 481 News and Release
