1:1 NAT on VPN100 version 10.03
MartyWalter
Is it possible to have a second static IP from the ISP and route it via 1:1 NAT to an internal server? If so, what is the proper configuration in Orchestrator to do so?
So once I set this AND I set a firewall rule, the 1:1 nat worked.
The next items would be using 1:1 nat within the autovpn.
i.e. Site 1 has a static IP from the ISP that I would like to route to a server at Site 2. Is this possible?0 -
@MartyWalter
On the 1:1 NAT, it mainly support 1 public IP map to 1 private IP. If you only have one Public IP, you could use port forwarding rules to fulfill your scenario.0 -
I understand how 1:1 NAT works, but what I cannot do is map public IP at Site 1 to a private IP in site 2.
Is the Site 2 behind router? If so, the site 2 should be mapped by public IP.0
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
