UAG5100 Guest login without code
Eddwood
Eddwood Posts: 33 image  Freshman Member
edited April 2021 in Security
Anyhow, I configuered something, that my guestdevices are able to log in without getting a code. Even when I log in the monitor section, the devices are not shown at ´login Users´. But I can see the device in the dashbord dhcp Table.
What have I done wrong?
  • Zyxel_Stanley
    Hi @Eddwood
    You can go to Configuration > Object > Address to Add IP object.
    After added this object, then you should able to find this object in drop down list of source address.
  • Zyxel_Stanley
    Hi @Eddwood
    If you would like to force client authenticate with UAG before access to internet, you may enable “Web-Authentication” function and setup client source IP address in the rule.
    In the default rule, lan2 client required to authenticate with UAG before access to internet.
    Of course you can add the rule to exclude IP address range for guest device without authentication required.(you may setup static IP on guest PC)
  • Eddwood
    Hello Stanley, Well, it works that I can´t login without a tickt. But I I can´t login anymore. In your picture ist on "source" the guestpc Range. I have a Vlan in lan1. with a different IP Range than the interface lan1. How can I switch the source from Lan1--subnet?
    The divece gets the correct VLan IP Range. in my case: 10.100.1.1/22
    The subnet in Lan1 ist: 192.168.0.0/23
  • Zyxel_Stanley
    Hi @Eddwood
  • Eddwood
    Thanks stanley. It works:))
