Your ideas could be new feature for WLAN!
Zyxel_Kathy
Zyxel_Kathy Posts: 76 image  Zyxel Employee
edited May 2024 in Wireless
Hello WLAN Forum Members,
Do you have moments that if your own thoughts or ideas can make better experience when using WLAN?
We can make your wish come true! star
Simply start a new post here describing your fabulous ideas for features or services you wish to have!
Once your ideas get lots of Likes 1 , we will give it to our product developers to have them evaluated and tell you the feedback!
Sounds cool?
Give Likes and Try it Now! B
  • Dateimanager
    Dateimanager Posts: 1 image  Freshman Member
    Hallo, ich wünsche mir eine Nachtabschaltung für WLAN
  • Zyxel_Freda
    Zyxel_Freda Posts: 397 image  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    Hi @Dateimanager ,
    The SSID can be disabled via setting the SSID schedule on NXC. You can edit the SSID in CONFIGURATION> Object> AP Profile> SSID> SSID List, and check the Schedule SSID to configure the time you want the SSID to be enabled or disabled.
