Where is the DHCP Table (hyperlink)
In former Zywalls there was a hyperlink on the homepage to direct you to the DHCP table. The new Flex 700 gives only a screen and number but no hyperlink to the actual table. Anyone knows where to find it, because it would be practical to find in the monitoring section, bit it never did in the older Zywalls, but it isn't still there in this newer generation?
Hi @Fender
It can display correctly after clicked on the number of DHCP widget.
Can you try to refresh(ctrl+F5) your browser and check it again?
BTW, I tested it by Chrome.
Hi @Fender
Hi Stanley, after a reboot en browser refresh the DHCP Widget is working now. Thanks!
- 588 USG FLEX H Series
- 477 News and Release
