How to risolve the problem with CLI error sh: ifconfig: not found
I’m using AMG1312-T10B, AMG1202-T10B, AMG1302-T11C and I want to manage them with ssh. I am able to change the password of WIFI with CLI command: wlancmd pskkey set -i 0 ***** and it works. But when I want to turn off the WiFi with command wlancmd up -i 1 it gives me the error: sh: ifconfig: not found. How can I fix it. Thanks.
Hi desman,
This CLI is not supported , if you wish configure the password please do so with the GUI.
As a notice, for the AMG products we have the Home Forum "https://homeforum.zyxel.com" whereas it is more likely to find discussions and FAQs regarding this product series.
Hope this helps!
5
Hi desman,
Hope this helps!
5 -
I’m using AMG1312-T10B, AMG1202-T10B, AMG1302-T11C and I want to manage them with ssh. I am able to change the vci and vpi I with CLI command for fix it. Thanks.
How do I save it
Hi @mk2802It is suggested to change the vci and vpi from GUI.
You can refer to the User guide for knowing how to set VCI and VPI on the GUI. Please search "Broadband" in the User Guide. Then you will be able to save the settings of VCI and VPI via GUI.
[UG of AMG1312-T10B]
ftp://ftp2.zyxel.com/AMG1312-T10B/user_guide/AMG1312-T10B_1.pdf
[UG of AMG1202-T10B]
ftp://ftp2.zyxel.com/AMG1202-T10B/user_guide/AMG1202-T10B_1.pdf
ftp://ftp2.zyxel.com/AMG1302-T11C/user_guide/AMG1302-T11C_V3.00.pdf0 -
hi.
i want to change via telnet.0
- 433 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 388 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
