bug- Set MAC address on default WAN1 sends default DHCP discover MAC and set MAC.
@PeterUK
After checked it internally, the customize MAC on Wan page mainly supports on USG 20 VPN and above models but not on VPN2S. It is incorrect GUI layout on VPN2S.
Regarding to this scenario, you can consider to implement it on USG 20 VPN.
I don't follow? What should happen is I set the MAC enable WAN1 and thats the MAC the DHCP client sends for a IP.
Currently if you set the MAC and enable the DHCP client send from the default MAC and set MAC for a IP. Are you saying the VPN2S can't send DHCP from the set MAC only?
Still think this is a bug unless its hardware offloaded for doing ARP and DHCP only the set MAC should be the source on a given interface.
- 385 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 908 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 200 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
