USG20-VPN is constantly pegging at 99% CPU usage and sometimes causes drops in network
Hi @Jford,
Use the command "debug system show cpu status" to check the details of CPU usage.
Router> debug system show cpu status
If the percentage of softirq is high, it means the CPU is occupied with traffic load.
If the percentage of system is high, it means the CPU is spent on running in kernel space.
You can then use the command "debug system ps" to check the process status.
Router> debug system ps
The firewall is at my house with a 100MB pipe. The firewall should not be maxing out on network traffic, ever. The configuration is a all computers and devices connect to a switch that connects to the firewall so internal traffic is not being handled by the firewall. The firewall only handles the traffic leaving the house. the 99% doesnt last long enough for me to identify that it has happened and then log into the firewall and see what is causing it. is there a log command that can be configured to autorun the commands mentioned above and log the results when the cpu load gets to a specific threshold?
The process that is maxing out the CPU is the one listed below.
python /usr/sbin/reg_agent.pyc 0 S182L44200495 BC9911BD856F 4.39(ABAQ.0)0 -
Hi @Jford,You can use the attached script "Get_status_loop_show_cpu_average.ttl" to automatically execute the following three commands automatically every 60 seconds.show cpu averagedebug system show cpu statusdebug system psOn TeraTerm, open Control > Macro and select "Get_status_loop_show_cpu_average.ttl".It starts executing commands on the console.
You can log all messages to a txt file automatically on TeraTerm> File > Log.
If you'd like to reboot USG, remember to click "End" to stop the script first.
I have exactely same issue since few weeks... reboot, disable all updates - nothing helps.Router# show cpu average
CPU Usage
0 15 %
CPU average: 15 %
Network Traffic: 7 %
CPU MEM TIME APPLICATION
3.6 0.4 01:29:32 SNMP server
2.4 1.3 00:59:48 Zyxel Service
2.4 0.8 01:00:50 IPsec VPN
1.7 0.2 00:43:57 Log
1.6 0.1 00:40:02 wacd
1.2 0.0 00:29:49 System statistics
1.1 0.2 00:28:23 User access management
0.8 0.4 00:20:52 ttyd
0.8 0.0 00:19:50 Process packets
Router# debug system show cpu status
CPU utilization: 86 % (system: 11 %, user: 66 %, irq: 0 %, softirq 9 %)
CPU utilization (1 minute): 62 % (system: 18 %, user: 37 %, irq: 0 %, softirq 7 %)
CPU utilization (5 minute): 62 % (system: 17 %, user: 39 %, irq: 0 %, softirq 6 %)
Router#PS shows no significant CPU usage of processes, except:29043 29038 python root ? 19 0 87.6 0.8 R 15076 8436 5088 3769 14:03:18 00:03 00:00:02 python /usr/sbin/reg_agent.pyc 3 8391643833fe00f1b1f3be8a949ea669e565ef9ad56846745c057ed5 4.60(AALA.0) noneedcnmidWhat tells me that there seems to be an issue with the sync to the cloud. Sometimes the problem disappear with no intervention, but comes back minutes later. The CPU usage of this process is always ~ 80%.ZyWall USG 40Current Version: V4.60(AALA.0)Released Date: 2020-10-17 00:06:21Never had this isse with last version of the Firmware. Maybe I'm going back ...0 -
Hi @ThomasCan
“ZyXEL service” is a process which will in charge of license status services.
29043 29038 python root ? 19 0 87.6 0.8 R 15076 8436 5088 3769 14:03:18 00:03 00:00:02 python /usr/sbin/reg_agent.pyc 3 8391643833fe00f1b1f3be8a949ea669e565ef9ad56846745c057ed5 4.60(AALA.0) noneedcnmidThis kind of service will consume CPU resource within a short period and won’t affect the system operation.
However, from the information you provide, we saw that the CPU average status shows SNMP sever with higher usage.
Are there many SNMP queries send to USG in the short time?
You may also share us the CPU usage in graphic view. It will display device CPU usage in past 24 hours.
I clocked your fetchurl_agent.pyc at 108%[2021-08-30 10:20:04.830] 2442 2426 python root ? 19 0 108 0.4 R 16920 9924 6376 4230 10:20:02 00:03 00:00:03 python /usr/sbin/fetchurl_agent.pyc 0 8a0dd579b64a8d6de25547429462c1e036448571d7dbf321f931f46a 4.65(ABAQ.1) USG20-VPN 4.65(ABAQ.0) USG20-VPNis this the new "reg_agent.pyc" that was hogging up process before?
Hi @Jford
The "fetchurl" is a background service to get correct URL for UTM function. Does process still displaying usage like it? You may update to latest version and have a check if display issue still exist.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
