Policy Control is Not Working
AlbertKang
IPs other than IPs of Test2 should not be connected, but access is possible.
Hi @AlbertKang
In the default policy control rules, there is no rule to allow the traffic from WAN to LAN.
And also in the last rule, it has blocked the traffic those doesn't allowed.
You may double confirm if there is any rule allows the traffic and check the last rule is stay in “deny” or “reject”.
Hi @AlbertKang
Thank you so much, but I can't see the setup screen after changing it to deny, so I'll try again after initializing it.
It works very well.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
