Policy Control is Not Working
AlbertKang
AlbertKang Posts: 2 image  Freshman Member
edited April 2021 in Security
IPs other than IPs of Test2 should not be connected, but access is possible.
  • Zyxel_Stanley
    Hi @AlbertKang
    In the default policy control rules, there is no rule to allow the traffic from WAN to LAN.
    And also in the last rule, it has blocked the traffic those doesn't allowed.
    You may double confirm if there is any rule allows the traffic and check the last rule is stay in “deny” or “reject”.
  • Zyxel_Stanley
    Hi @AlbertKang
  • AlbertKang
    edited December 2020
    Thank you so much, but I can't see the setup screen after changing it to deny, so I'll try again after initializing it.
    It works very well.
