Zywall 110 Firmware upgrade
Thank you!1
Hi @Raffa
You can upgrade firmware by this steps:
410AAAAC0 > 420AAAAC0 > 430AAAAC0 > 435AAAAC0 > 438AAAAC0 > 460AAAAC1.
I will send 4.20/4.30/4.35 firmware to you by private message.
The other versions, you can download them after logged on to Myzyxel.com.
Thank You!0
Zyxel_Stanley,
I also need to perform the same upgrade (ZyWALL 110 running 4.10). Can you send me the 4.20/4.30/4.35 versions as well?
Thanks so much.
Thank you!1
I also need to perform the same upgrade (ZyWALL 110 running 4.15). Can you send me the 4.20/4.30/4.35 versions as well?
- 432 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 387 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
