LTE firmware for SBG3600
I cannot get LTE working. Can you provide me with the latest firmware versions, current installed FWs are as follows:Current Firmware Version: V1.00(AAKO.6)Current WWAN Package Version: 1.15Current Firmware Version: ALT3100_04_05_06_10_B8_LO
Thanks0 -
Hi @Zyxel_VicI got a Zyxel SBG3600-N and tried to get it running again. Unfortunately the LTE module doesn't work
My Firmware is V1.00(AAZN.8) - LTE: ALT3100_04_05_06_10_B8_LO
I cant find ANY support on the official Zyxel page anymore, even though I understand the modem is "only" 2-3 years old...
Can you provide me with the most current FIrmwares (both Device and LTE) so I can use it again?
Would not like to through it into the bin...
Pls send me a firmware update as well, thanks !0
Hello, My current version of the LTE firmware is ALT3100_05_00_02_00_81_MS. Can you please help me to get an updated version? Best regards.
Hi Psaa, Mahaba, Mikko_jurvelin,
Please check your inbox.
Hi Pascal,
The ALT3100_05_00_02_00_81_MS is already the latest release.
Regards,
Bob0 -
Will you kindly send me newest firmware and LTE firmware update to my SBG3600-NB00
thx
Hi Danny,
Please check your inbox.0 -
HiWhere I can find the changelog for the firmware ALT3100_05_00_02_00_81_MS?
Hi Mautkok,
Requesting the newest firmware for Zyxel SBG3600-N0000
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
