VPN L2TP active (in listen) on nr. 2 distinct wan
AndreaB
AndreaB Posts: 1 image  Freshman Member
edited April 2021 in Security
Dear Zyxel Users,
on the fireall zywall usg 310 I have programmed nr. 2 wan in failover. Both wan (WAN1 and WAN2)
are defined with their own static public IP on the relative interface (ge1, ge2).
On the primary wan (WAN1-ge1) the L2TP VPN on IPSEC is configured regularly and running.
I need to apply the same L2TP VPN configuration on IPSEC on the second wan (WAN2-ge2).
How can I implement this solution?
Cordially,
Andrea B.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    Hello AndreaB,
    As your description,
    The current design may not fulfill this requirement since users can select only one profile in L2TP VPN setting page.
    However, the IKEv2 VPN can satisfy your scenario, so check and follow the attached SOP of IKEv2 example as your reference.
    Charlie
