WAC6502D-E schedule reboot
Hi all,
I'm trying to schedule reboot of my WAC6502D-E.
I have created and uploaded a shell script reboot.zysh with this commands.
After I open Putty and write the commands below:
configure terminal
reboot
Router# configure terminal
Router(config)# schedule-run 1 reboot.zysh daily 03:00
After I click enter it shows a parse-error.
Please see the picture.
Many thanks.
Kind regards,
Fabrizio
Many thanks.
Kind regards,
Fabrizio
Hi @pootheyes
So far, the schedule-run command is supported on controller, not on standalone AP. If you have PoE switch connecting to AP, we suggest to use PoE schdule to reboot the AP.
Joslyn0 -
HI Zyxel_Joslyn
Many thanks for your feedback.
I connected the AP to the telecom Modem via Powerline.
So I enabled wifi in the AP where all devices are connected.
I would like to schedule a reboot of the AP during the night because sometimes the wifi has problems and all devices lose the connection.
How can I solve this? It is frustrating.
Many thanks
Fabrizio
Just wonder if this could be the powerline issue? for some powerline adapters have their own power saving mechanism, where uplink will be auto disabled when there's no outgoing traffic for a period.
Maybe next time you can try to pull out and plug in the cable between AP and Powerline device instead of rebooting AP, and check if the connection is back.0 -
Hi @pootheyes
I think we should resolve the connection issue instead of rebooting the AP. Can you help to collect the diagnostic when all devices lose connection? We will analyze it and find the root cause. MAINTENANCE > Diagnostics > Diagnostics. Please send it via private message to me.
Joslyn0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
