WAC6502D-E schedule reboot
pootheyes
pootheyes Posts: 2 image  Freshman Member
edited May 2024 in Wireless
Hi all,
I'm trying to schedule reboot of my WAC6502D-E.
I have created and uploaded a shell script reboot.zysh with this commands.
configure terminal
reboot
After I open Putty and write the commands below:
Router# configure terminal
Router(config)# schedule-run 1 reboot.zysh daily 03:00
After I click enter it shows a parse-error.
Please see the picture.
Many thanks.
Kind regards,
Fabrizio
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @pootheyes
    So far, the schedule-run command is supported on controller, not on standalone AP. If you have PoE switch connecting to AP, we suggest to use PoE schdule to reboot the AP.
    Joslyn
  • pootheyes
    edited December 2020
    HI Zyxel_Joslyn
    Many thanks for your feedback.
    I connected the AP to the telecom Modem via Powerline.
    So I enabled wifi in the AP where all devices are connected.
    I would like to schedule a reboot of the AP during the night because sometimes the wifi has problems and all devices lose the connection.
    How can I solve this? It is frustrating.
    Many thanks
    Fabrizio
  • Greenlight
    Greenlight Posts: 57 image  Ally Member
    Just wonder if this could be the powerline issue? for some powerline adapters have their own power saving mechanism, where uplink will be auto disabled when there's no outgoing traffic for a period.
    Maybe next time you can try to pull out and plug in the cable between AP and Powerline device instead of rebooting AP, and check if the connection is back.
  • Zyxel_Joslyn
    Hi @pootheyes
    I think we should resolve the connection issue instead of rebooting the AP. Can you help to collect the diagnostic when all devices lose connection? We will analyze it and find the root cause. MAINTENANCE > Diagnostics > Diagnostics. Please send it via private message to me.
    Joslyn
