site2site vpn access to more that one remote LAN
mike13
mike13 Posts: 2 image  Freshman Member
Seventh Anniversary
edited April 2021 in Security
Hi
I have a need to give access to more then "basic" LAN at remote site
SiteA
    (somekind of IPSEC router)
    remoteLAN1: 192.168.92.0/24
    remoteLAN2: 192.168.294.0/24
SiteB
    Zyxel Zywall 110
    localLAN1: 192.168.8.0/24
The site2site tunnel works great between localLAN1<->remoteLAN1. but there is a need to access remoteLAN2 form localLAN1.
Gateway for localLAN1 is Zywall110 so there is probably a need to configure correct routing on Zy110.
this solution worked in prevoius setup (with PFSense as a SiteB router) so probably nothig must be changed on SiteA
does anyone have an idea about?
