USG intranet route
there intranet are usg60: 192.168.1.0/23 and asus: 192.168.10.0/24
gateway is 192.168.1.1 and 192.168.10.254
I already use a cable connected their lan(usg60 was Lan1) port,
How should I set on USG60 just can let usg60 .1.x can ping/connect to .10.x
So your setup looks like this:
Hi @mz_ghost
Here should be your scenario:
USG60(LAN: 192.168.1.1/23)-------------(WAN: 192.168.1.X/23)ASUS(LAN: 192.168.10.0/24)
You can add static route on USG60.
Then destination address is 192.168.10.0/24 traffic will forward to ASUS router.
Of course you have to make sure ASUS router has allowed the traffic.
but the ASUS lan had it's WAN out(from Asus Wan),I just would like let their two lan can connect each other0
Hi @mz_ghost
Did you connect cable between USG60 LAN port and ASUS LAN port?
Both of LAN port are belonging to different IP subnet, so it is impossible communicate with each other.
If your ASUS router support to establish Net-to-Net VPN Server, then you may have a try it.
If I want my ASUS lan can connect to ZyXEL USG60 Lan,still just write static route 192.168.10.1 to gateway 192.168.1.1?If I need do some modify on USG60 to allow 192.168.10.x packet in?0
So on port 3 of the USG60 don't connect it to the ASUS LAN.
On port 4 zone to LAN2 of the USG60 setup a new network 192.168.10.1 255.255.255.0 (no DHCP) connect this port to the ASUS LAN then in the ASUS setup for static route put in 192.168.1.0 255.255.255.0 (in your case 255.255.254.0) gateway 192.168.10.1. This may work
Then allow LAN1 to LAN2 and LAN2 to LAN1.
Hi @PeterUK
As your suggestion may have IP overlap situation on ASUS route…..since WAN and LAN are belonging to same IP subnet.
It may cause traffic unable send out successfully.
You can connect ASUS WAN interface to USG60 LAN port. Then ASUS WAN will have IP address as “192.168.1.X”.
Then create static route on USG60:
Destination: 192.168.10.0/24, NextHop: 192.168.1.X(ASUS WAN)
Then traffic should be work.
Yes, since the ASUS ip sharing had two wan interface, It's a way.so USG and other device's LAN can't connect each other just use their LAN port and static route?0
Hi @mz_ghost
Since those 2 LANs belong to different IP subnets.
So the traffic can’t just communicate with each other directly unless there is another router routes the traffic between different subnets.
Or you can connect the ASUS alternate WAN port to USG60’s LAN port
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
