Set USG210 VPN to NAS
I have attached image of the configuration. Is it done right? NAS_Ip_SUB is correct ?0
the ip of the nas in ppp is 10.0.0.1 but my lan network is on 192.168.1.x how can i make sure that that ip 10.0.0.1 is assigned to the ip 192.168.1.x? otherwise I can't see it in network resources0
Hi @dmmichael
NAS offered 10.0.0.2 to USG after PPP interface is established.
So you can create policy route for your NAS connection.
Source: LAN1_Sub, Destination: NAS_Real_IP(X.X.X.X), NextHop: WAN1_PPP, SNAT: Outgoing interface.
When user access to NAS_Reak_IP(X.X.X.X), then traffic will pass by PPP interface.
Hi Stanley thank you. I'll explain. the nas has a local ip address 192.168.1.30but it is not in my network but in another city, to access it I use the public ip 93.147.xxx.xxx (I have omitted the last numbers for privacy). When Usg connects to the nas through ppp it receives the address 10.0.0.x in fact if I insert the ip on my pc \\ 10.0.0.1 the Nas folders open (after entering login credentials). now how can i make the nas respond on ip 192.168.x.x? so that anyone going to network resources can access them? without having to manually enter the ip \ 10.0.0.1? thanks a lot0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
