USG Flex 700
jayd691
jayd691 Posts: 17
First Comment Nebula Gratitude Third Anniversary
edited April 2021 in Security
I just received my new Flex 700 and after going through the quick setup process and upgrading the device to the latest firmware, 4.60 Patch 1, the device will not shut down when using the gui. It appears to hang after receiving the command and the message shows on the web gui "Device is shutting down..." and the time keeps going but the device does not power off. Do I need to send this device back or is this a known issue being corrected. The only way I can turn off the device is by turning off the power to the device which is not good.
  • jayd691
    jayd691 Posts: 17
    I have another question. How do I allow the GS1920-24HPv2 switch to use the Flex 700 as the NTP server? I can use an outside time server, but I generally always use the firewall/router for the time for downstream devices. If I set the NTP server address to the Flex 700, the switch cannot update its time.
    Please bear with me as I am re-learning the Zyxel devices after a long absence! Thank you.
  • Zyxel_Tobias
    Zyxel_Tobias Posts: 200
    5 Answers First Comment Friend Collector Fourth Anniversary
    Hi @jayd691
    The Flex can´t use as NTP Server, it only can act as NTP client. So it still need Switch to use external NTP Server.
    Thanks.
    Kind Regards,
    Tobias
Security Highlight
