Specify IP
class
class Posts: 13 image  Freshman Member
edited April 2021 in Security
I HAVE 6 IP,
EX: xxx.xx.xx.49~54
My mail Server want use .54 to send mail
But, it always send mail by .49
What should I do to achieve my goal
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    You can go to Configuration > Network > IP/MAC Binding to bind E-mail server mac address with a static IP (just as the following example) and release, renew E-mail server IP address. Finally, check your IP address If been changed and test it again.
  • class
    It can use virtual interface IP?
  • Zyxel_Jeff
    Hi @class
    Would you mind checking your VM server interface setting? We suggest that it set to bridge mode(such as following virtual-box setting).
