VPN2S, no access on "inside" nor Internet
USJKPAS
USJKPAS Posts: 1
edited April 2021 in Security
I'm connected via DDNS as client to site via VPN2S but cannot reach any hosts on my office LAN, also the Internet connection get's lost. Shall something more be added in the firewall or port forwarding to get it work?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,338  Zyxel Employee
    Hi @USJKPAS
    You can navigate Web-GUI Configuration > NAT > Port Forwarding > Add > Add a port forwarding rule and then you can access your VPN2S LAN area host. Such as the following example you can access internal web server.
  • Josta
    Josta Posts: 2
    Hi, is there a way to enable the above via CLI via a Ssh connection?
  • Zyxel_Jeff
    Hi @Josta
    It’s not recommended to configure the settings by using CLI since it’s mainly used for troubleshooting instead configuration. Feature deployment via CLI may not as completely/straightforward as GUI.
