What's New for ZLD4.60 patch 1 (available on Dec. 15)
Thank you for choosing ZyWALL ATP and USG FLEX series. Zyxel is committed to continuously updating your devices for the most advanced features. This latest release enhances all-round functions of ZyWALL products including:
SSL inspection and performance enhancements
To prevent advanced masqueraded attacks, we elevated security with TLS 1.3, while the enhanced SSL inspection performance has gained up to 3-5 times faster.
Enhanced account security by Two-Factor Authentication
Added an extra 2FA protection for admin and VPN connection by SMS, email, and Google Authentication. Safely let users use their personal devices to log in to the private network for increased productivity.
DNS Reputation, powered by McAfee (ATP only)
DNS Filter prevents reaching those known domains hosting malicious content and reduces the risk of phishing attacks, obfuscate source IPs using hijacked domain names.
APC 3.60 supports new WiFi6 APs and provides more comprehensive features
WAX510D, WAX650S will be supported for full management, while the WPA3 support is added on 11AX AP, CAPWAP enhancement, and more features will escalate the security and manageability.
Great news to all our USG FLEX users, we've developed a new USG FLEX 100W/700 for a comprehensive solution. USG FLEX 100W* integrates dual-radio WiFi for solid wireless performance. USG FLEX 700 brings a complete suite of security subscription with seamless, scalable gateway connectivity to SMBs.
*: Availability may vary by countries.
Resolved Issues in ZLD4.60 Patch 1 Release
1. The resolved issues table listed below does not list every bug that has been corrected with ZLD4.60 Patch 1; for inquiries about a particular bug, please contact Customer Service & Support. |
Table 1: Enhancement
Table 2: Resolved issues
Hi StanleyIs the new FW published?I don't find it on the "online check" of the device and also not at portal.myzyxel.com.Thanks for an update.Mario
and is the FQDN objet bug always present ? (need to hard reboot after the update ?)0
Mario said:Hi StanleyIs the new FW published?I don't find it on the "online check" of the device and also not at portal.myzyxel.com.Thanks for an update.Mario
It is available now. I put it on my home system and it fixed an issue with L2TP/IPSEC VPN introduced with the last update. I have not had a chance to explore it much further yet.
Is there any information about 2-Factor Authentication with Google Authentication?
I only found information about usage for enhanced security to login in the Zyxel account webpage. The information above however could give the impression that this is also available for VPN connections.0 -
Maybe this post helps you:
I'm getting the following error on my VPN50:
port: p2led has undefined status:orange
anyone ?
Is the ssl VPN performance also better in ZLD4.60?
Hi @bind
The ZLD4.60 patch1 purpose is to fix Vulnerability of CVE-2020-29583 and doesn’t enhance VPN performance than ZLD4.60 patch 0.
You can refer to the following link about CVE-2020-29583: https://businessforum.zyxel.com/discussion/5400/what-you-should-know-about-cve-2020-29583-and-actions-to-take-to-mitigate-the-risk#latest
Thanks jeff, yes I know this about patch 1.
But does zld4.60 patch 0 enhance performance for SSL VPN (not ssl inspection)?0
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 922 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
