USG60 L2TP VPN with 2 wan
I have 2 problems with the l2tp configuration on firewall USG60W
First problem:
If I configure l2tp VPN with VPN wizard in "easy mode" everything works correctl, but if i try to do the configuration manually in "expert mode" I can't get it to work.
Second problem: more serious
How do I set up two VPN l2tp to be able to connect using 2 wan interface?
I currently have two connections with 2 different ISP
WAN1 public ip a.a.a.a
WAN2 public ip b.b.b.b
LAN: 172.30.160.x
IP-range used for VPN 192.168.100.5-192.168.100.205
With VPN wizard I can create the l2tp connection on WAN1 or on WAN2.
But I have to create two connections on both wan interface so the user can access vpn using public ip on wan1 (a.a.a.a) or public ip on wan2 (b.b.b.b)
UPDATE.
I solved the first problem!
UPDATE 2
Solved also second problem see https://businessforum.zyxel.com/discussion/1146/usg-l2tp-backup-connection
UPDATE.
UPDATE 2
2
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
