VPN2S not blocking by default UDP 500
PeterUK
PeterUK Posts: 3,887  Guru Member
edited April 2021 in Security
With no L2TP VPN or IPsec VPN on the WAN only a IPsec VPN connecting to the LAN at 192.168.255.202 for Site-to-site.
Sending a Identity Protection (Main Mode) UDP 500 to the WAN replays with Informational by the VPN2S.
Workaround make firewall rule to drop from WAN to router.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,337  Zyxel Employee
    Hi @PeterUK
    There are some points need to clarify:
    (1)   What is your test topology? Could you illustrate it?
    (2)   What is the symptom? and test procedure? Could you describe them more detailed?
    (3)   Could you provide your configuration file(Maintenance > Backup / Restore > Backup) with and without workaround solution via private message to me?
    VPN2S to WAN and make a windows 10 VPN L2TP connection over 4G to WAN of the VPN2S.
    Send you a packet capture of the symptom and what you need to send to WAN on VPN2S.
