Do I need a modem or router?
[Deleted User]
[Deleted User] Posts: 3 image  Freshman Member
Do I need a modem/router when using MULTY?
  • [Deleted User]
    Check my scenario at my house, it works properly.
    Internet---Modem---<WAN>---Root MULTY)))<WLAN>(((Extend MULTY
    How's network topology in your house?
    Do you have modem which provided from ISP?
  • [Deleted User]
    @Hanamichi
    Thanks for your feedback, I only have one router at home, but the wifi signal of my mobile phone is weak in some corners. so I want have wifi system devices.
  • [Deleted User]
    [Deleted User] Posts: 4 image  Freshman Member
    @Vivcat,
    MULTY does not replace your router,
    but it connects to your existing router to give you fast WiFi throughout your home. :smile:
