Can I rename the 11ac 5 GHz wireless network?
[Deleted User]
[Deleted User] Posts: 2 image  Freshman Member
I noticed it only adds ".speed" to the 5 GHz wireless network.
  • [Deleted User]
    @Kiley_Minogue,
    2.4GHz and 5GHz is used the same SSID by default.
    Do you want to separate SSID for 2.4GHz and 5GHz?
  • [Deleted User]
    I already separated the wireless network 2.4 GHz and 5 GHz, but it only defaults with "mynetwork.speed"
    What if I don't want to add ".speed" or rename the 5 GHz wireless network to something else? Where do I do that in the app?
  • [Deleted User]
    [Deleted User] Posts: 10 image  Freshman Member
    Test
